What iphone app is the best for BS5/BM5?
Plugplayer is running perfectly on my iPhone 4 and iPad 2
I have a Problem to add beomaster5 as mediaserver to plugplayer (ipad1-Version), do i have to connect manually by entering the beomaster ip adress at Plug Player? thx matze
I am OK with Eyecon. Couldn't do wel with Twonkey.
When you select devices, don't you see beomaster 5? Is media server turned on?
Musicserver is activated, do i need to Enter ip Adress at Plug Play manually?
1. I have tried a lot of apps, but I'm still searching for the one that can make my BS5 look cool like normal NMusic playing. I want it to show nice 500x500 resolution covers on my BS5 when selected on my IPad.
2. All players seem to stop after one song on the selected CD when selected on my IPad?
Any good experiences out there?
Henrik
I like eLyric. Can add multiple items to a playlist. Has option to "shuffle" and "play all" in some screens. As for cover art, some of my tracks have cover art that looks exactly like when I play N.Music. Some are perhaps of a slightly lower quality, and some are missing. I am thinking it has to do with the manner I loaded the music. The few sample songs that came pre-installed on the Beosound look just as they do in N. Music mode,....beautiful.
App will also turn entire system on and can adjust volume from it, but is a bit touchy. The volume display will even respond on my BV7.
I have elyric too, but i can't power off beosound 5 with it. Somebody have a tip? I use beosound5/ beomaster5 and the sound on my beovision7.
With elyric it is possible to have a server different (from beomaster5) a nas for example and the player is beosound5 !
But i can't see beomaster5 on the server only some other NAS
THanks
I do not know of any way to use eLyric to power off the Beosound 5. I use the Beo 4/5 to turn off.
I have Beomaster 5 appearing in my eLyric as an option for both server and renderer.
thanks Razlaw . I haven 't beomaster 5 as an option for both server  and renderer, only beosound5 for lecteur (renderer). May be there is an option in beosound 5 to activate? because i see all the others dlna/upnp server ( NAS synology, Imac,..)
is there a way to read on beovision7 the movie (.avi, .divx on beomaster5) with an ipad app as we listen audio?
