Virgin New tivo box xml
Happy new year to you all
Does anyone have an xml file for the new virgin tivo box so i can directly control it using my beo6?
Much appreciated
A Happy New Year to you as well.
I have created what I believe will work with a Virgin Media TiVo and you can download it
Thanks a lot for that keith, i will give it a go and let you know how it works.
I have made a few xmls my self which i am happy to share however my buttons are allways on the touch screen and then i manually copy them to the hard keys. Is there a way i can do all this within the xml?
as at the moment i have to manually copy to each of the hard keys everytime i do a new config. Hope that makes sense to you?
Thanks again
Louis
If you send me the XML files you have made yourself to keith@beoworld.org I will return them with the hard keys pre-assigned.
I do not copy-n-paste as has been suggested, that would take much to much time..
Hi Keith,
Sorry for the slow reply been flat out busy! The Virgin Tivo XML worked perfectly.
Thanks for that. I will send you all the XML's i have made as soon as i get 5 mins this week.
Thanks for your help!
Louis
