I have managed, largely thanks to the excellent advice on this forum, to set up my BeoSound 5. Special thanks to all, especially Mr 10% who's advice and answers to previous posts pointed me in the right direction.
I do have a couple of small issues, that may be because of my lack of understanding about the various role options of the BM5/BS5, or just that I am expecting too much, hopefully someone will be able to advise me.
My set up is as follows, BeoMaster 5 has no speakers connected, the BM5 is masterlinked to my BeoSound 9000 Mk3 to which the speakers in the main room are connected, and to several linked rooms all with Beolink passives, as far as operation from the Beo4 remote is concerned, everything works perfectly in all locations.
What I am confused about is when operating the system in the main room directly from the BeoSound 5, I have to manually select N.Music on the remote to activate the BeoSound 9000 in order to hear anything, again when changing the volume level on the BS5 using the wheel, nothing happens, I have to increase or decrease the volume on the BeoSound 9000 by using the remote.
I would have thought that as the BeoSound 5 is designed to be operated directly with all its wonderful tactile wheels and levers, that somehow the relevant information would be sent along the masterlink to the BeoSound 9000 to react accordingly, even though I appreciate that the majority of sound settings in this set up would of course be controlled by the BeoSound 9000. Turning the system off however, using the standby buton on the BeoSound 5 isnt a problem, and works perfectly.
I have tried various roles and options on the BeoSound 5, setting it as an Audio Master, regardless of the option, simply freezes the system, so it is currently set as Audio Master Off and the BeoSound 9000 is in option 1.
Apart form the above, which as I mentioned may be me expecting too much, it all works perfectly, and has only frozen once, and that was when I was uploading an extended mix of Olivia Newton John singing Xanadu, which is understandable really!
Kind regards,
P
