The usual software issue when updating ConfigTool
I had to update mine several times before I could find the software version 3.30a in the Beo 6.
Thanks for the information. But it does not work for me. I have tested a number of times without success, by downloading new konfigruation to BEO 6. It still shows Software version 3.0. Anyone have any tips and hints on how to succeed?
I also tried to download the configuration from my "old" configprogram after I tried with 6.62. Then the Beo6 got hung up and showed "No Valid Confugration" on the screen. Then I changed back to the 6.62 version and tried again. If this did the trick or my multiple tries - I don´t really know. Maybe it helps....?
Thanks ! The lastest tipps from you helped. Now I finally have version 3.30a, in my Beo 6. B&O software is everything other than the obvious.
I just got back two of my Beo6 from service with the battery drain problem, but unfortunately they did not do the 3.30a update. So I am still on 3.00a and afraid to have again two dead paperweights in a few weeks...
As the CT 6.62 does no longer allow logging in without user credentials, I was not able to download the new firmware. Any tricks with older software did not work for me.
Would anyone please be so kind and share his CT user credentials, so that I could update my Beo6.
Any help is highly appreciated.
Looked everywhere for this software, Please sent me a link to the newest config tool 6.62. Too !
unfortunately CT 6.62 won´t help without user credentials to enable downloading the newest firmware.
Is there anyone out there, who would be able to share working user credentials to enable a CT login?
There must be some kind of dealer login.
Thanks for any help.
Best regards
Is anybody sharing the latest version i would be grateful for a copy please?
I thought this forum is also to help others. There are members who have the config tool (see posts on this forum)
So please share a link to the config tool 6.62.
Please send me a link to this software
Many thanks
