the ct tool 5.12
 hi. I decided  to make my beo5 change. But I couldn't find the lastest version of the ct tool. (5.12)
Unfortunately, In my country Dealers don't give that program...
How could I get that program from the web?
I struggled to find that in this forum, but failed....
Thanks for the replies in advance.
Here http://www.mediafire.com/?ja5fh442qq6x4kz
 thanks a lot. I got it.
i think you can get the CT 4.11 and not the CT 5.12 with the link below ?😮
Configuration Tool 5.12 is here:
Thanks, I am just downloading it.
Has anybody installed it yet and could it be installed over 4.11 so all the settings can stay or is it again not compatible?
Installation removes the previous version (4.11 in my case). To preserve my Beo5 configuration, I backed up the folder "Clients" from c:\Bang & Olufsen\Beo5 Configuration Tool\Clients and my custom logos from c:\Bang & Olufsen\Beo5 Configuration Tool\Images\Logos\Custom
After installing 5.12 I copied those folders back to the new installation, and was able to continue configuring the Beo5 from the current, previously saved state.
Okay that sounds good and also all dats stays and can uploaded etc?
I'd say yes -- at least in my case the upgrade from 4.11 to 5.12 was smooth. All programming was preserved, as long as I copied the "Clients" and "Images/Logos/Custom" to the 5.12 installation.
I could simply continue configuring the Beo5 from where I'd previously left off.
