[SOLVED] XML file for Toshiba LED TV (CT-90326)
I am not so certain that your code captures are incorrect because you previously tested the MENU test XML and it worked and included within your latest file was also the MENU, so I loaded both XML files and compared the MENU output and they were exactly the same meaning at least the Menu command in the new full XML file should work.
When you come back from holiday, perhaps you could re-test the XML file before going to the extent of re-capturing the IR codes
You was right. I was tryed  newly downloaded attached file and uploaded it in to remote control. The new file is mostly working but some buttons not.
Not working SW buttons: "TEXT", "LANGUAGE", "ATV/DTV", "POWER", "8", "STAND BY"
Not working HW buttons: "LEFT", "BACK" ("RETURN")
I found some Pronto codes for non working buttons. I tryed to configure my harmony 555 remote to these remote and buttons was worked for me.
Only, what I'm not found is navigation left button and BACK button. I need to build a new Ir capture HW, to capture this button 🙂
Could you please convert these codes and replase in exist xml file.
Yes! Finaly I was corrected binary codes, all buttons works fine.
I will thank you, Keith, for your help in creation codes from my data!
The mistake was in data codes bit values. The inverted values did not match with data codes. After corrections now all buttons I need, works well.
The complete XML file is attached for download.
Kind regards,
