Hi All,
I'm looking BEO5 XML file for Toshiba TV (model 40HL933)
Would like to get som of these functions: ON/OFF, Volume, inputs, up/down/left/right/OK, quick, return and exit.
Thanks in advance
Hi All,
Thanks in advance
I do not have a ready built XML file for your model of Toshiba TV, but nearly all Toshiba products use NEC IR protocol and if you can find some Pronto HEX codes posted on-line then an XML file could be built from them.
Also, if you have the means of capturing the IR codes from your exist original remote, that clear would be the best way forward because you will be certain that they would work.
Thank you for replay Keith .
I will try to capture IR codes with UIRT2B device, which was built a long time ago . Only need to find right software. Do you know, is Girger or WinLIRC config files can be used to get codes?
There is a Girger plugin available
I use RS232 version of UIRT 2
Here is example for "MENU" button
Force RAW Mode learning>
R030FB5580E090E090E090E090E090E0A0E200F090E200E200E200E200E200E200E090E200E200F1F0E090E200
E200E090E200E090E090E090F1F0E090E090E200E090E200E
IR Debug mode>
09 4C B5 58 0D 0A 0E 0A 0E 09 0E 0A 0E 09 0E 09 0E 20 0E 0A 0E 20 0E 20 0E 20 0E 20 0E 20 0E 20 0E 09 0E 20 0E 20 0E 20 0E 0A 0E 20 0E 20 0E 0A 0E 20 0E 0A 0E 0A 0E 0A 0E 20 0E 0A 0E 0A 0E 20 0E 0A 0E 20 0E FF
03 0F B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0E FF
07 7D B5 2B 0D FF
07 7D B5 2B 0D FF
07 7D B5 2B 0D FF
07 7D B5 2B 0D FF
I hope some of them is a right format and can be used.
I have used your RAW data to convert this MENU command and the pulse, pause pairs define the number of 50 micro-second pulses or pauses.
I have manually translated your RAW data into a form which we can understand better as below:-
Pulse, Pause in micro-seconds
09050,04500 = 13450
00700,00450 = 1150
00700,00450 = 1150
00700,00450 = 1150
00700,00450 = 1150
00700,00450 = 1150
00700,00500 = 1200
00700,01600 = 2300
00750,00450 = 1150
00700,01600 = 2300
00700,01600 = 2300
00700,01600 = 2300
00700,01600 = 2300
00700,01600 = 2300
00700,01600 = 2300
00700,00450 = 1150
00700,01600 = 2300
00700,01600 = 2300
00750,01550 = 2300
00700,00450 = 1150
00700,01600 = 2300
00700,01600 = 2300
00700,00450 = 1150
00700,01600 = 2300
00700,00450 = 1150
00700,00450 = 1150
00700,00450 = 1150
00750,01550 = 2300
00700,00450 = 1150
00700,00450 = 1150
00700,01600 = 2300
00700,00450 = 1150
00700,01600 = 2300
00700,64000 = 64700
This translates to a 32 bit NEC protocol with an address of 40BF and a command code of 5BA4
From this I have created an XML file with just this menu command in it for you to test. Extract the ZIP file to C:\ and it will be put into the correct directory of the configuration Tool
Great success! Menu button that you created is works well. Now I need to capture all another codes to create complete XML.
I try it tonight, because at the moment I get many errors while truing to capture IR signals. While capturing, the learn progress bar is jumping forward and backward. (mayby is too sunny and this affect to ir receiver. ) Only what I can capture at the moment codes in UIRT format (form "MENU" buttot it looks follow 430A454145F0). Can UIRT format data can be used?
Finaly captured all buttons of remote. If you could please create new XML file.
Clearly, I was not going to convert each of your captured codes manually as I had done with your MENU test, so I have written a small Windows based programme which takes each of your captured entries and converts them to Pulse Pause format which I can then make into an XML file.
The attached XML file has the digits and hard keys pre-assigned.
Please let me know how you get on with the testing..
Wow thanks for qick reaction 🤒
Unfortunately last XML file codes not working. I think the problem is in captured data. I still can't get stable remote codes. Something is wrong with hardware.
I will go to holiday tomorow, and have not acess in to my equipment until end of August. I can capture new codes after my return.
