Hello All
Is there the possibility to run a slide show (pics are on BM5) and having music playing in the background (using the mp3's on BM5) at the same time?
Thanks for any idea and a happy new year!
Wulf
Hello All
Wulf
Sure. Press PC to start your BM5 and BV. You will get the main menu. Select N.MUSIC - music starts up. Press MENU and select PHOTO. Press MENU - 3 (slideshow). Now you listen to N.MUSIC and watch photos from your BM5.
Hope this helps.
Stefan
Thank you for the quick answer Stefan. Sometimes life is easy 🙂
