How can I change option with my BEO5 remote?
I have a Beovison 8-26(New module in it DVB-T) connect to a Beosound3000 with a ML cable! A pair of Beolab8000 speakers are connected to the TV.
So I need to change option to???
Hi there!
You have to set the options first through the confihurationsoftware so these are uploaded to Beo5 and then by pressing option in front of the device it configures it directly.
Best regards
Spiros
Spiros is correct, the following two images overviews the action which must be taken in the Configuration Tool.
Right click on the product and left click on SET OPTION
Thanks for the help! Now it´s working just the way i want.
Next problem :(
I have a external sateliterreceiver connected to my BeoVision8-26 connected to a scart. I managed to programming TV logos and it works fine.
But i cant manage to get the "step_up" and "step_down" button to work on the channellist! Wich command should i use?
Sorry for bad English...
Your English is very good..
What is the make and model number of your STB ?
Are you controlling the the STB using the PUC of the Beovision 8-26 ?
My box is a Pace DS250NV. But it´s not in the list on the TV Menu can only find a Pace DS230.... But it all worked fine before I got he DVB-T/ML unit mounted!
What is PUC same as IR? I use the IR in the Beovision 8-26 to control the STB
PUC means "Peripheral Control Unit" located in your Beovision and can be updated from a Laptop with new STB from the B&O library.
The B&O library currently contains templates for Pace DS230, DS420NV and DS460, but not the DS250NV
If your Pace DS250NV previously worked prior to the installation of the DVB-T/ML with the TV menu set to Pace DS230, then it is likely that your STB may be connected to the wrong port. Check the AV port assignment for the STB, you may well find its connected to the wrong one.
I haved try AV4, AV3, AV2 and AV1. Only AV1 is working with my box.
I have managed to erase my Beo5 from the settings my dealer programed. Maybe the problem is the in the Beo5??
Thirst time I managed to program my remote was today... Only the TV icons work as it should. CD, Radio and computer works fine to... but change channel with the arrows does not work!
Any suggestions what to do?
If you are saying that everything works correctly except the arrow buttons to change the channel, then it is almost certain that the PUC entry is not 100% compatible with the STB you are using.
Yes yes, I managed to get it to work! Now I can shift programs with the arrows.
The solution was this command:
0:000:0:TV:PLAY
0:000:0:TV:STEP_UP / DW
