I would like to have Cable digital and Sat parallel and I assume that works.
My Beo 6 is in mode 'DVB-HD D, CH, A (Multifeed) as TV' and not '...as DTV' which means on BEo 4 you push TV and not DTV . Is this right and sufficient?
Also have the Option set to cable digtal and Sat, so can I use it parallel and is there any other settings to be made in the Beo6?
There is also an otion 'use TV and DTV for external sources'. What does that mean?
Thanks & regards
Oliver
