Samsung Blu-ray and Beo5
Hi guys.
This is my first post on this forum.
I'm thinking of buying a Beo5 or Beo6 to be able to control set-top box, dvd. etc.
I have found this Samsung BD-D6900M  http://www.samsung.com/uk/consumer/tv-audio-video/blu-ray-players/blu-ray-players/BD-D6900M/XU/index.idx?pagetype=prd_detail
The nice thing about this box, is that it contains both a Blu-ray player, DVB-C tuner, and a USB connector (more or less anything I need).
I have played a bit around with the B&O configuration tool, and it doesn't seem that complex.
Does anybody know, if the TV(BV 8-32) and the remote supports this box?
All the best
Niels
I have that very same Samsung blu-ray player and can definitely recommend it. It has dual hdmi ouputs so it can output 3D on a 3D screen while sending the audio to a BeoSystem 3. This player can play just about anything you throw at it in terms of video or audio files using filed burned to a DVD, filed on a USB stick, or even an external hard drive connected via the USB port. It also has just about every smart tv app you can think of: YouTube, Facebook, Pandora, Netflix, etc. Also, it has wifi built-in.
I was able to control everything perfectly using the generic Samsung blu-ray controller in my BeoSystem 3 PUC. Pushing the "green" button switches from menu navigation mode to transport mode for fast-forward, rewind, etc. One problem I've find with the generic Samsung blu-ray template on the Beo5 (for use with the B&O PUC; not the direct IR control from the Beo5 to the Samsung BD) is that the green and red buttons do not respond on the first page on the Beo5 menu. Rather, you have to go to the second page of the Beo5 menu to get the green and red buttons to respond. This SHOULD be correctable via editing of the Beo5 programming but I haven't fiigured it out.
What a great suprice!
Do you know how to figure out if my BeoVision 8-32 has that generic Samsung blu-ray template in it's PUC, like yout BeoSystem 3 has? It's a bit older you know.
Hope that you will be able to help!
All the best
Niels
If it's similar to the BeoSystem 3, you probably need to go into the "menu" settings (perhaps pressing "menu" twice?) to see the setup of your connected devices. In that menu system, you can see what devices are available to you in the PUC. The PUC items depend entirely on what your dealer programmed for you based on the needs you discussed. For my BeoSystem 3, I planned ahead by having my dealer program quite a few brands of blu-ray players and tvs into the PUC just in case I would ever need them. Chances are that your dealer probably only programmed into the PUC would you said you would need. Your dealer can always program more devices into your PUC...usually for a fee, though.
BTW, this blu-ray player has a brushed aluminum top that fits in really well with the B&O look. The front panel is touch-sensitive, and it has a slot-loading disc feature instead of a disc tray. With the dual HDMI, you could probably add an external tv for 3D viewing. The prices have come down considerably so that they are quite inexpensive. I recently got a 64" Samsung 3D screen for $2400 USD. This blu-ray player has an option in the settings to send the video signal through both HDMI outputs as well so you could receive the video signal through both your BV 8 and an external screen. However, if you're not planning on using it for 3D, there are much cheaper Samsung blu-ray players out there that do the same thing. There is one that is very thin, brushed aluminum, and wall-mountable, but it does not have the dual HDMI outputs.
Correction: The unit you're looking at only has one HDMI output. That unit looks just like mine with the brushed aluminum top but yours only has one HDMI ouput instead of two. It's the Samsung BD-D6700 that has the dual HDMI output.
Thank you so much for your help.
I just checked the PUC list, and there were only 4 items in it. Unfortunately they were all were old and unusable.
Is there any way to load in new PUC's?
Sadly, this is something you'll need your dealer to do for you. I would recommend having your dealer load extra items for your PUC just in case you might need them later. For example, Apple Remote (for Apple TV), Sony PlayStation 3 (which is also a great blu-ray player), Generic Samsung Blu-Ray, Generic Sony Blu-Ray, etc. Sony and Samsung are pretty reliable about re-using the same codes in their products.
Do you think that the Beo5 will be able to control the Blu-ray player directly? or does it have to go through the TV?
There have actually been four versions of the Samsung Generic PUC file (G-BDPXXX) created by B&O on the following dates:-
  • 15th August 2008
  • 15th December 2009
  • 20th April 2010
  • 10th May 2010  -- Current Version 2,10a
I don't know when you had your PUC updated, but if it was not in the last year, then you may have an earlier version
The Samsung Blu-Ray Player CAN be controlled DIRECTLY provided you have an associated XML control file.
