Reset MOTS?
Is it possible to reset MOTS? I find it always seems to select tracks from the same albums almost regardless of the seed track. I am getting to the stage of culling some of these albums. Is this a sign that MOTS has nort really analysed all the tracks properly - It has had 10 days or so for around 100 albums.
Tip for new BS5/BM5 owners - do not include albums/tracks just because you own them, you need to really like them also just in case MOTS selects them.
Is MOTS as useless as a man's nipples?
Apparently it won Music algorithm of the year, lord knows what the quality of the second prize was!
Please discuss...................................................................
I'm convinced about MOTS !!
I use it all the time, it will give you an other view of your music collection.
I have 40.000 songs onit  and it is able to select perfectlly matching music.
Mine has all kind of music going from very very soft music to even metal
I do not think there is "button" or tool to reset mots.
you can do some deletions in the system (mots directory) but because it is a database this is not the best way to do it ..
May be the easiest way is to delete all music, reinstall the box and recopy all music on the system, this should take not so long to do it.
Of course the mots process will take some time again ... (i think max a day for 1500 songs).
nico
I thought it might get to doing a reinstall...
Anyone else noticed a similar state of affairs with MOTS. I don't mind the selcetion but I feel it can be a bit narrow and always seems to focus on the same old artists/albums. In its defence sometimes it is surprisingly accurate in selecting similar pieces. I just wish it would surprise me more from a wider selection of artists/albums.
I think it is what it is - a clever way of giving a more "themed" random playback than an ordinary shuffle feature.  Many say it's cleverer than the Apple Genius feature but then again that still gives a themed random playback of it's own making. Maybe MOTS is too clever and doesn't vary off piste enough as propaganda suggests.
Is it the future of music listening? - I think not, it is a nice to have feature that you should be able to select when you want it and not when you don't. Maybe it should include a weighting factor that can be preset to determines how similar the next selection needs to be?🤔
What would be useful is an on/off and an exclude completely feature, perhaps some filtering parameters would be useful. I think B&O have oversimplified the way it works to the detriment of the overall experience. MOTS should be an option not a default, and when engaged should always surprise the listener (in a nice way of course).
I seems that there are a few songs in my collection that it will eventually play no matter what the seed.  I have deleted a couple of these songs so I would not get sick of them.  I will probably add them back after a while and see if the same thing happens.  Sometimes it may take ~30 songs before it gets to one of it's favorites...  It might be my imagination, but (to me) it does seem to favor recently added music so maybe deleting and adding a bunch of songs might mix things up a bit.
Yes, the abililty to specify whether an album/song is included in MOTS would be a great enhancement.  For example, many Frank Zappa tunes are inappropriate for certain company, but I'd like the convenience of spinning the wheel vs. finding the CD.
Having said this, I do think it works very well 99% of the time.  What I've found about it that I really like is that there's apparently a lot of music that I stopped listening to because I didn't like the entire album, or the album was "too long" (can listen to 15 minutes, but by 30 mins, it's becoming tedious).  MOTS has reacquainted me with this music... a song or two at a time.
Stan
Thanks Stan. MOTS is a great idea but not executed quite as well as it could be. Unfortunately my BS5 keeps playing tracks from about three artists when there are many many others to choose from regardless of the seed track. It is a bit irritating. I do agree that you do discover forgotten tracks, this can be a great pleasure.
Is there an easy way to dump the current MOTS list and start from a new seed? I cannot figure how to do this as selecting a song and holding down "GO" seems to add that track to the list rather than reseeding the list.
Unless you're playing an album or artist, MOTS is always on so selecting a new song reseeds MOTS.
If you hold GO on the Beo4, it will reseed MOTS using the current song.  Unless you're playing an album or artist, this doesn't usually change things tremendously because the songs are already similar.  That is, the song is already in queue with songs that are similar according to the MOTS algorithm so re-seeding with a song in the queue will only usually cause subtle changes to the queue.
Stan
The easiest way to "reset" the MOTS is to reinstall the Beosound software, then it will reset all the indexes. This is better than deleting all the music. You will have to use the service menu on the Beosound to do this.
