Hello,
I have just had a BV7 installed by the dealers and I'm using the BEO6 to control it. I never had a BEO5 so this kind of remote is all new to me and I must admit I absolutly love it. Very easy to use once programmed.
Anway one problem I have got is controlling my PS3 with the BEO6. I have purchased a RE-BL X and my Bang Olufsen dealer has downloaded the XML file from the re-bl website and added it to the BEO6.
Does anyone on here use the re-bl x? If so can you give me a rundown on your "on" and "off" sequences?
When I press PS3 on my BEO6 screen it turns the tv on to the correct AV output and brings up the re-bl pages on my BEO6. I then scroll to the next page and press " Standby" which turns on the PS3 and the PS3 start up menu appears on the tv. I can then use the BEO6 to control the PS3......great.
My "off" sequence is a little strange.
When I press "PWR OFF" on the re-bl page on the BEO6 the PS3 turns off but the tv goes into a black screen mode which cannot be turned off with the remote. To escape from this screen I have to select another av source ( i.e Sky) then turn the system off altogether with the red power off button on the BEO6.
I was thinking that there might be a tv off sequence missing from my BEO6 re-bl porgram.
Any ideas?
Kind Regards,
David.
