Password for Beomaster 5
Hi, after long waiting my Beosound 5/Beomaster 5 has arrived. When I install Beoplayer on my PC the system asks for a password for the Beomaster 5 and I can't find it anywhere in the documentation. Has anyone installed the BM 5 ? Where do I find the password ?
Best regards
Halid
after you have set the pw in the settings menu of bs5/bm5, enter the same pw in beoplayer.
Thanks for fast answer ! And where do I set the password, in the BS 5 you mean ?
/ Hans
/ Hans
select "mode" on bs 5, then focus on settings. RIGHT, LEFT, RIGHT, LEFT, GO.
after the settings menu appeared, browse through the menus for the password section.
enter the password, thatsit.
When I choose mode and then choose settings, everything that comes up is :
- System info (end )
- System settings : here are two choices, Language and Time Zone
- Maintenance : here are also two choices, Clean-Up and Update software
I can't find any password settings anywhere. Am I doing something wrong ?
/ Hans
pls do NOT choose settings, only focus on it, then push RIGHT LEFT RIGHT LEFT GO an the full service menu choice will collapse
Now it works !!! Can't thank you enough !
Best regards
Halid
Did you really have to install it yourself? Where did you buy this...?
It was my own decision to install it myself.
/ Halid
Hope you can help me. I have the same problem that my iMac doesnt connect with Beomaster5.  So i cannot transfer CD`s from iTunes to Beomaster5. I have also changed the passwort in Beosound5. But it doesnt connect with my iMac. My configuration is:
1.iMac 10.5.x
2. Beomaster5/Beosound5
3. Beomaster5 connected with my iMac with the encludet Ethernet-kabel.
4. Software BeoConnect
5. The Beomaster ist brand new from an B&O Dealer (But now the office is closed)
regards
musi1958
