Nokia DBox 2
Hello, in the beo5 configuration tool (Version 1.00, Serializer-Version 0.35) i cannot find my dtv nokia dbox 2 (non B&O Products, Sources). I know that there at least existed STB-Controllers for this STB. How am I able to use it with my 7-40 Mk3?? Thanks TS4
Whilst the STB controller (PUC) has the Nokia Dbox 2, the Beo5 Configuration Tool does not.
You have two options available to you:-
- You can create your own template if you are familiar wilh XML format for the Nokia Box, the best way is to take an existing file that is near the Nokia Dbox 2 and modify it and save it as the Nokia Dbox 2. The nearest one which is in the Tool is the Nokia 9902S
- You could just use the Nokia 9902S template and just modify the few Icons which have different commands.
