I've just discovered the following:
If your music has NO cover, the Beosound 5 shows a default cover (white sphere or s.th. like this).
It is possible to exchange that for your own picture :-)
There are 3 files in the Beomaster/Data directory:
- 0coverDefaultSmall (PNG)
- 0coverDefaultMedium (JPG)
- 0coverDefaultLarge (PNG)
You can replace these files with your own pictures!
I've just tested it with the "0coverDefaultLarge" png file and it works like a charme.
Be sure to make a backup of the original files and rename them e.g. "backup_0coverDefaultLarge.png" and then copy your own file into the directory.
Use an image editor to identify the dimensions of the picture. I tested the large picture (500x500 pixel).
No Cover? Use your own picture instead of B&O original
I find the coverimage at google.dk and then change the name to Folder.jpg and it works fine.
I put in a picture on my daughter on one album, thats fun, brgds Ingvar
I didn't refer to covers of the original album:
The BS 5 uses default pictures if it can not find any album cover and I changed the systems default picture!
