I'm running 3.57 on my old xp laptop, beacuse my new Win7 64bit dosent support beo5 remote and software..
Can 3.59 solve my problems?
Best Regards
Mads
Best Regards
Mads
Hello Mads,
short answer. No! Windows 7 does not support the 3.59-Version of Beo5 CT. It is the same Driver-Problem like in 3.57. The Beo5 will be not detected in 64bit-Versions.
Have a nice Easter-Weekend
Beroli
Hey and thank you alot...
Okay, but i still works on my old laptop.. What are the new functions in 3.59?
Good Easter to you.
Mads L P
I had the same problem with Windows 7 but didn't want to run it on an older XP machine. I got around it by downloading installing the Windows XP Mode for Windows 7. Basically, it creates a virtual XP machine within your machine. If the Virtual XP 'machine' crashes, it has no effect on your Windows 7 operations.
The config software now runs flawlessy on my Window 7 64 bit machine.
Hans
Doses some one now where to download 3.59 ?
Hi MADSLP,
I too run with Windows 7 64-bit and found that the BEO5 configuration program doesn't run under W7 64-bit.
However, I did find a workaround. If you download the the WINXP mode for Windows 7 ( link http://www.microsoft.com/windows/virtual-pc/download.aspx ) and install it, you will be able to run the program under W7. Do not forget , once the XP mode machine has started, to attach the BEO5 to the virtual machine. It works well on my setup.
Good luck!
Peter.
O well, just saw the update from Hans with the same message. Sorry for the double post.
Peter.
Thaks HansB, i worked also fine for me..
Anytime...hey, where did you get 3.59? I haven't seen it available anywhere yet. Let me know.
Hans
I haven't the 3.59, but I will also like too. You let me know..
