Where can i get the new Configuration Tool version 6.84 for the mac can you help me to send me the link or software
The configuration Tool was only designed to run on a Windows operating system.
Hi Keith,
when i connect my beo6 on my pc i het A error on my USB poort, i have Windows 10 64 bits is that A problem.
It can be, generally speaking its best to use it on a 32bit XP system - I have a virtual mashine for just that. But not all config tools run on 64 bit, what version have you tried installing?
On Windows 8 and 10 you will need to install the USB driver manually. Have a look at my answer HERE for Windows 8/8.1
Just download it from http://www.mediafire.com/file/6s2l3qs88zqz9x1/CTSetup_6.84.exe
If you only own a Mac, there is no reason to invest in a Windows laptop just to use the config tool. You can run any Windows VM on a Mac easily using a program like that http://www.parallels.com/products/desktop/ This is what I do.
Having never used Windows on a Mac with no CD drive. How do I add Windows to Parallels once I download it - or does it already come with it?
Hi, could you be so helpfull and send me the version? Thx a lot
