New Configuration Tool version 6.84, for Beo5/Beo6. Released to day.
I search it also urgently!
So do I.
riishoj@gmail.com
It's  now impossible to put any IR third party comand on a macro ?
I have made any change for Cinema ON :
0:000:TV:CINEMA_ON
Delay:3000ms
0:000:LIGHT:CIFFER_0
Delay:3000ms
ON-OFF
0:000:TV:CINEMA_ON
The ON-OFF is a third party command to switch on my Sanyo 3000 projector. Before the 6.84 config tools there were no problem and now, the ON-OFF command isn't accepted anymore (when I clic on the ADD button, nothing happen)
It's a little bit strange because 0:000:LIGHT:CIFFER_0 which is a Lutron third party comand as no problem and is accepted as before.
Thank you for your help if there is anyone who make special comand with configuration tool.
It was mentioned that the new sofware doesn't support 3rd party commands on the hardbuttons anymore - which is a very dumb move from B&O!.
Maybe they kicked the 3rd party functionality out of the macros, too!?
This is the reason why I do NOT update to the newest software: I will loose functionality of the Beo 5.
Can you provide me the link to download this new version?
Could I also have a download link please?
Hi, Can someone please send me a copy of the new configuration tool? I tried the steps listed on the previous page, but I keep getting an error message with my e-mail. I would really appreciate some help.
So how did you guys get the new CT? there are no links and most people beg to get it...
Can you kindly send me the New Configuration Tool version 6.84, for Beo5/Beo6 to me?
I dont think more than a few ever got it :(
