PLEASE - just look at this (found somewhere, sorry, no source saved):
To the moderators: If the following does not fit the forum rules, please delete my post.
As many people need help to find the ConfigTool 6.62 , here is the answer:
This was written somewhere in the archived forum but I can't remembre where.
You find the tool in the danish forum beoforum.dk but you must register to see the subforum for the software.
I used google translate to register, but the following is my little HowTo to register for non danish speeking people as I am:
On page link click on "Tilmeld" at the bottom left of the page to register.
You get to this page :
at the upper right select British English in the "Sprog:" field.
Click on "I agree to these terms"
Fill the needed fields and resolve the "Captcha" question by draging and droping the items to the right column:
Disse er kendte Bang & Olufsen udtryk. These are known Bang & Olufsen look.
Disse ting er ikke Bang & Olufsen udtryk. These things are not Bang & Olufsen look.
submit.
When logging in on the Index page, , on the bottom left
Brugernavn: Username:
Kodeord: Password:
you will see in the "Beo5, Beo6" Forum a Subforum "Subforum: Konfiguration Software" which isn't displayed when you are not logged in.
Here you will find the Config Tool in different versions.
- PLUS -
Just a little clarification about 64 bit,
The Version 6.0 and above Configuration Tool can be installed and update a Beo6 on 64 bit Windows operating system.
The Version 6.0 and above Configuration Tool can be installed on a Windows 32 bit operating system and fully supports the Beo5, BUT not 64 bit because there is no 64 bit USB receiver in the Beo5 firmware. If you do connect a Beo5 to a Windows 64 bit system, the driver for Beo5 will fail to be installed.
When the Beo6 has been upgraded with the new software, it can no longer be configured in a version 5 or older version of the Configuration Tool.
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
