hello, i have a Beo5 and i want control my Tv Sony, player bluray Panasonic, Tvix Slim S1....Clim Sanyo...
where can I find the xml file for my products ?
Thx
Thx
The Beo5 is programmed by dealers and those customers who have a copy of the B&O Configuration Tool.
Included in the tool is everything you need to program a Beo5/6 to control all modern B&O products and a range of B&O partner third party products such as Lutron lighting.
The configuration details of all products are defined in a standard XML file which only becomes important when you wish to control third party products not defined by B&O within the Configuration Tool.
The hardware and firmware of a Beo5 and Beo6 supports third party IR codes which have a carrier frequency between 30Khz and 80Khz, but to make use of this facility an XML file has to be made for that particular third party product and then it can be added to the B&O Tool and used in the normal way.
Making an XML file can be a difficult task depending on the third party product you are using. If you have the orignal third party product remote control then the first thing you need to do is establish the carrier frequency used, knowing the IR protocol is needed for some protocols particularly RC5 because of the way we must handle the"Toggle bit"
You can also look
Ok thanks keith, but how to download xml file for the Pace CubePac1 on the Wikis 3rd Party Products ?
and where can I find a list of products of different brands with their xml on the forum?
