Thank you Keith for all your help on this.
Unfortunately, there is no other option to capture the signals with IRTRans.
I even tried to capture with a second IRTrans module (I have 2 modules, one USB, another Ethernet), but I always got the same codes :
I also tried to send the IR code from the IRTrans module, and it worked well : I managed to turn ON and OFF my Mitsubishi Projector.
ON
Basic Capture : S000011112100000100
Advanced Capture : (N)4(1)8392 4208(2)520 552(3)512 1608(4)520 4216(RC)2(RP)31(FREQ)39(SB)(RS)(D)S000011112100000100
Basic RAW : 0 32 192 0 16 120 512 560 512 552 512 560 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 128 512 1624 512 560 512 568 512 560 512 568 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 120 520 552 512 560 512 552 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 136 512 1616 512 560 520 560 512 560 520 560 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 128 512 552 520 552 512 560 512 552 512 1600 512 1616 512 1600 512 1608 512 0 16 136 512 1616 512 568 512 560 520 560 512 560 520 560 512 1608 520 552 544
Advanced RAW : (RAW)135(FREQ)38(D)0 32 192 0 16 120 512 560 512 552 512 560 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 128 512 1624 512 560 512 568 512 560 512 568 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 120 520 552 512 560 512 552 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 136 512 1616 512 560 520 560 512 560 520 560 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 128 512 552 520 552 512 560 512 552 512 1600 512 1616 512 1600 512 1608 512 0 16 136 512 1616 512 568 512 560 520 560 512 560 520 560 512 1608 520 552 544
OFF
Basic Capture : S000011112010000100
Advanced Capture : (N)4(1)8392 4208(2)520 552(3)512 1608(4)520 4216(RC)2(RP)31(FREQ)39(SB)(RS)(D)S000011112010000100
Basic RAW : 0 32 200 0 16 112 512 552 520 552 512 560 512 552 512 1608 520 1592 496 1632 488 1624 512 0 16 136 488 592 488 1632 520 560 512 568 488 584 488 592 488 1624 496 576 544 0 120 1976 0 32 176 0 16 104 496 576 488 576 496 576 488 584 488 1624 512 1608 496 1616 496 1632 488 0 16 152 496 584 488 1632 496 584 520 560 512 568 488 584 520 1600 496 576 544
Advanced RAW : (RAW)89(FREQ)38(D)0 32 200 0 16 112 512 552 520 552 512 560 512 552 512 1608 520 1592 496 1632 488 1624 512 0 16 136 488 592 488 1632 520 560 512 568 488 584 488 592 488 1624 496 576 544 0 120 1976 0 32 176 0 16 104 496 576 488 576 496 576 488 584 488 1624 512 1608 496 1616 496 1632 488 0 16 152 496 584 488 1632 496 584 520 560 512 568 488 584 520 1600 496 576 544
If these convert signals dont work, what would you suggest I get in order to capture the codes ? (which Lintronic Box is the best ?)
Thanks !
Olivier
