Need Help !!! XML for Mitsubishi Projector... I have IRTRans
Thank you Keith for all your help on this.
Unfortunately, there is no other option to capture the signals with IRTRans.
I even tried to capture with a second IRTrans module (I have 2 modules, one USB, another Ethernet), but I always got the same codes :
I also tried to send the IR code from the IRTrans module, and it worked well : I managed to turn ON and OFF my Mitsubishi Projector.
ON
Basic Capture : S000011112100000100
Advanced Capture : (N)4(1)8392 4208(2)520 552(3)512 1608(4)520 4216(RC)2(RP)31(FREQ)39(SB)(RS)(D)S000011112100000100
Basic RAW : 0 32 192 0 16 120 512 560 512 552 512 560 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 128 512 1624 512 560 512 568 512 560 512 568 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 120 520 552 512 560 512 552 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 136 512 1616 512 560 520 560 512 560 520 560 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 128 512 552 520 552 512 560 512 552 512 1600 512 1616 512 1600 512 1608 512 0 16 136 512 1616 512 568 512 560 520 560 512 560 520 560 512 1608 520 552 544
Advanced RAW : (RAW)135(FREQ)38(D)0 32 192 0 16 120 512 560 512 552 512 560 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 128 512 1624 512 560 512 568 512 560 512 568 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 120 520 552 512 560 512 552 512 560 512 1600 512 1608 512 1600 512 1616 512 0 16 136 512 1616 512 560 520 560 512 560 520 560 512 568 512 1608 512 560 536 0 120 1984 0 32 144 0 16 128 512 552 520 552 512 560 512 552 512 1600 512 1616 512 1600 512 1608 512 0 16 136 512 1616 512 568 512 560 520 560 512 560 520 560 512 1608 520 552 544
OFF
Basic Capture : S000011112010000100
Advanced Capture : (N)4(1)8392 4208(2)520 552(3)512 1608(4)520 4216(RC)2(RP)31(FREQ)39(SB)(RS)(D)S000011112010000100
Basic RAW : 0 32 200 0 16 112 512 552 520 552 512 560 512 552 512 1608 520 1592 496 1632 488 1624 512 0 16 136 488 592 488 1632 520 560 512 568 488 584 488 592 488 1624 496 576 544 0 120 1976 0 32 176 0 16 104 496 576 488 576 496 576 488 584 488 1624 512 1608 496 1616 496 1632 488 0 16 152 496 584 488 1632 496 584 520 560 512 568 488 584 520 1600 496 576 544
Advanced RAW : (RAW)89(FREQ)38(D)0 32 200 0 16 112 512 552 520 552 512 560 512 552 512 1608 520 1592 496 1632 488 1624 512 0 16 136 488 592 488 1632 520 560 512 568 488 584 488 592 488 1624 496 576 544 0 120 1976 0 32 176 0 16 104 496 576 488 576 496 576 488 584 488 1624 512 1608 496 1616 496 1632 488 0 16 152 496 584 488 1632 496 584 520 560 512 568 488 584 520 1600 496 576 544
If these convert signals dont work, what would you suggest I get in order to capture the codes ? (which Lintronic Box is the best ?)
Thanks !
Olivier
Oliver,
Based on your feedback I have concluded that the captured data is correct, the issue is how IRtrans software has displayed the data.
The information we know for sure from your data is:-
  1. It uses 39 Khz Carrier
  2. The start bit is 8392 4208
The core problem for me is two elements, first the basic binary string has a "2" in it -- S 0000 1111 2 0100 0010 0 -- binary is "1" or "0"
Secondly, I have determined that any IRtrans RAW Pulse or Pause with a value of greater than 2048 micro seconds is split into two bytes starting with a "0" as in 0 32 200 -- This must mean their device uses a 12 bit processor.
Taking into consideration what I stated above, then from the "ON" RAW first 8 bits which is the device address is:-
512 552 = 0
520 552 = 0
512 560 = 0
512 552 = 0
512 1608 = 1
520 1592 = 1
496 1632 = 1
488 1624 = 1
The second 8 bits are the command
488 592  = 0
488 1632 = 1
520 560  = 0
512 568  = 0
488 584  = 0
488 592  = 0
488 1624 = 1
496 576 = 0
I think that the "2" shown in the binary string is a bug in IRtrans software because Mitsubishi are one of the very few company's to use a double pause between the device code and the command which is usually about 4200 micro seconds.
In your captured "ON" example the value of the Pause is 4144 microseconds made up of 0 120 1976 which is 2040 + 120 + 1976
Taking the above into consideration I will create an XML file tomorrow for you to try.
Olivier,
I have created an XML file for you to test based on my conclusions outlined above.
You can download the ZIP file containing the XML file
Thank you Keith for all your help, but unfortunately, after copying successfully on my Beo5... the projector doesn’t give any answer to the commands, neither with OFF-1, ON-1 or POWER...
I really appreciate your help on this, and I dont want to abuse...
But I really dont know what i could do now...
Olivier,
I am sorry to hear it is still not working.. Clearly, there is still something incorrect.
I think the best action would be for you to send me your original remote control, so that I can capture the commands.
I will send you an e-mail with my address..
Olivier,
After receiving your remote I did a quick check and it turns out that what I decoded and provided in the previous download was correct in as far as the protocol decode was concern.
The protocol used in “Proton” and uses a 38 Khz carrier Frequency.
However, the reason my file did not work is because this projector expects the same code to be sent at least 3 times for each command and I only sent it once. This protocol does not have any error detection, so what they do is wait for the command 3 times if it decodes as the same command, then it is executed. It is possible that it may have worked if you had pressed the button 3 times very fast.
Anyway, I will create a new XML file for you to test.
I Keith,
I'm discovering this thread and it seems that Olivier's problem is really close to the problem I had with IRTrans and 2 of my remotes (Philips HomeRun + Sony videoprojector) : "2" in the captured string, which works by resending it with IRTrans but not with your XML... I will also try to see if sending 3 times the code makes something to any of my devices... But before that, I need to have a PC at home in order to use the Config Tool 😕
Keith,
Thanks a lot for your help, i received your latest test file, and everything is working perfectly well !!!! Thanks a lot !!!
MBee,
I'm using Parallels on my Mac in order to launch the Config Tool, and I can do whatever i want.
Concerning the 3 times sending signal, pressing very fast 3 times the button on the Beo 5 didn’t work : I had to configure the Beo5 with the config tool in order to send this signal 3 times.. that worked well
Olivier
Olivier,
I am very pleased that everything is working well for you now.
mbee
After receiving IRTrans captured codes from Olivier and others, its clear there is some issues with its outputed information from a capture, but the capture itself is fine. For example it does not provide information about "repeat" codes etc.
I suggest you post in the same way as Olivier a couple of captured commands from Homerun and the Sony Video Projector and we can see if we can successfully convert them, now we know the limitations of the IRtrans capture.
