MOTS wont finish
Hi
I received my BS5 last Friday (4th), and I must admit, it is a fantastic music system, it has replaced my BS6500.
However, the MOTS took quite some time to finish, or, almost to finish. I have about 17.000 tracks on the BM5 and it took about 1 week to get to 96% finished, but the last 4 days it has not progressed any further.
Does anyone know what I can do to get the MOTS to 100%?
The MOTS does work, though.
Thanks in advance.
Hi beolin,
i have the same "problem". I have the Encore since Saturday. And it works Day and Night to finish the MOTS. (you musst have the Encore in Standby). I have similar much songs than you. In the first day i have seen the coloured semicircle halfdone, yesterday it was always the same. I think you have right, it takes much of time. So at moment MOTS is inactive although i select MOTS in the settings.
Greets
My MOTS did not work before it reached a certain % in completion, cant remember the %, but it works fine now.
But my system still need the last 4%.....The 17.000 songs took about 6 days to get to 96%.
I just called my dealer, and he said that there is a bug in the SW for BS5, which can cause the MOTS to go into a loop, so that the system freeze. And my 96% completion should be caused by the same problem.
BS5 SW update is currently planned to take place 24/11.
oh thanks for answer!!!
hope the update includes reading Apple Lossless Files!
Greets
and, the software update fixed my problem :-)
