Maintenance Mode
Stefan, you are a GOD!
Thank you so so much. I've done it.
I have tried this and got to the maintenance mode - where can I find the IP address? Which section I tried looking but cannot find it? I remember reading on this forumn that you should be able to find the IP address from this mode? If not how else can I find the IP address?
Also how do you exit this mode?
Thanks,
Arvind
On the maintenance menu, select "Network Info" (third choice from bottom up).
The third item is "IP Address".
To exit from maintenance menu, select "Mode" (first choice), then select "N.Music" or "N.Radio".
Thanks got it now - should be looking properly!
Arvind
