Logitech Harmony Playstation 3 Adapter: Can anybody make a Beo 5 file out of the Pronto Hex file?
Thanks for your replies.
I brought the PS3 Harmony adapter back to the shop where I bought it because the adapter is incompatible with the new PS3 slim - according to the Logitech forums.
Now  I'm waiting until Logichtech improves the adapter and then I'll test it again with the Beo 5 and hope that it works :-)
Hello,
I'm asking for an update:
Does anybody of you use the Beo 5 successfully with a Logitech Harmony PS3 adapter and the PS3 SLIM?
According to Logitech there's an improved version that should work. You can identify it on the bottom of the PS3 adapter.
There's a label called "PID".
All the new and improved adapters have a PID higher than LZ922xx.
They adressed the problem and have it in their support database:
http://forums.logitech.com/t5/PLAYSTATION-3/Harmony-Adapter-for-PS3-and-PS3Slim-users-Solution-for/td-p/386807
If it successfully works with the Beo 5 I'm gonna buy that adapter again :-)
I have managed to create a new XML file which seems to work, but I have not hade time to do anything with it and mapping to hardkeys etc is beyond my knowledge of XML. I sent the new XML file to Keith a while back but I do not know if he has had time to look at it and do his usual magic including mapping of hardkeys etc.
//Rolf
Rolf,
Sorry for the delay in getting back to you on this one.
I have today taken your XML file and re-constructed it so that the hard keys can be used.
Once you have confirmed that it all works correctly, I will add it to the download site.
Keith Saunders wrote:
I have converted the Logitech Harmony PS3 Adapter Pronto codes for you into a Beo5 XML file including digit and hard key assignments.
You can download it link and then extract it to C:\ which will add it to the correct directory in the Beo5 Configuration Tool.
Within the Beo5 Tool just drag-n-drop to your configuration as below
Hello Keith
I see you have LG TV under others?
Where did you get this from, can you send me the XML file on this, or a like?
My tv is LG PS8000 also called 50PS80
please email me the file, if you have if (sblochm@hotmail.com)
Thank you again.
BR
Sblo
A warm Welcome to your first posting on Beoworld..
Like all the XML files I make available for download, I produce them.
Generally speaking LG use the same codes for most recent TV's and you can download the file
Dear Keith,
I see in your Product Browser (Beo5 CT) a 3rd party XML for a Samsung TV. Is this XML also for a Samsung LCD?
I want to use my Beo5 in the bedroom (Samsung LCD with Ouverture, BL8000 and LC2) and buy a new Beo6 for the livingroom. Looked for a Samsung TV file in the Beo5 download page but found no Samsung files. Just found the Samsung Hex-codes on "remotecentral.com" but can't convert them to XML. Would you want to share your Samsung file with me? If you like I have the 3rd party files for a Philips LCD TV and a Humax STB. Also have the CT4.11 if you like.
Thanx,
Dave (Buchten, Netherlands)
