Logitech Harmony Playstation 3 Adapter: Can anybody make a Beo 5 file out of the Pronto Hex file?
The first (original) download file I provided will work perfectly with version 3.0 Configuration Tool AND 1.41a firmware.
It will not work if you have firmware version 1.34a in your Beo5.
Ok, that's reassuring me.
Keith, another dumb question:
I'm gonna make a complete new configuration with the 3.x config tool and the 1.41a Firmware and send it to the Beo 5.
Do I have to place the Beo 5 on the charger the whole night to recalibrate the battery or how should I do it the best way?
NO, you should not need to do that.
Press the standby button down and then press OK (Centre button) to go into the SETUP menu then press INFO and if the battery shows full, then you should not have a problem.
Ok, I asked because of your big red tip in the Config Tool V3.0 review where you hint at the new calibration that seems to be required?!
To clarify the battery situation..
With Version 3.0 and its associated firmware if you create a 3rd party XML file incorrectly, particularly if you are using RAW which leaves the transmitting LED on or in constant repeat mode, then the battery will show flat within minutes. If you have correctly created an XML file, then you should not have any problems.
Thanks for clearing that up, Keith!
And always: A big thank you for your help and support! I'm gonna try it out and will give you feedback tomorrow  or tuesday as soon as I have time to test it out!
I've made a configuration with 2 test zones: One with the file for firmware V1.4x and one for V1.3x.
None of them is working, PS3 shows absolutely no reaction.
The adapter seems to work ok as it paired fine as a BD remote control with the PS3.
Any hints, tips?
I just used the raw file, no customisation like reanging buttons etc. as it was just for testing because I do some work.
Beo 5 Firmware: 1.41.a
Hardware Revision 6
Supported Version 0.39 (this information is displayed in "Beo 5 Version Info window of the Config Tool 3.x)
Hello Keith and T.W.G.
I have just uploaded the provided Logitech Harmony PS3 Adapter XML file to my Beo5 (s/w 1.41e) with the config tool 3.23. As T.W.G I get no reaction at all from the PS3 (or the Harmony Adapter) despite the PS3 reporting that it is paired with the adapter.
I do not own a Harmony One remote so I cannot verify the functionality directly but I do have the Lintronic kit so I will try to reverse engineer the Remote Central codes a little to see if I can find any discrepancies.
T.W.G have you come any further with the issue ?
//Rolf
TWG
If you PM me your emailadres i can give a PS3 xml file.you can test it.I dont have a PS3 for to test on.I did put them from a site on in a BEO file
regards
Jan
I have just remapped the available Pronto codes from the Remotecentral site and converted them into Beo5 format via the Lintronic Configurator tool. The commands now seem to work from the Beo5, and I will now spend some time not to map the commands to the Beo5 including the hardkeys. Failing this I'll ask Keith to give me a hand.
In any case one step ahead today.
//Rolf
