Lintronic Software
Hey all,
can anyone tell me, how i know on what Frequenzy a remote is sending its code? Inside the Lintronic Software when i look at the curve of the Codelearn Generator. Or when i click High/Low, i somehow cant figure out where the frequenzy is.
regards
I might have to explain it better. The XML Generator has a Dropdown Menu with the Frequenzy. How do i figure that out when i look at the Lintronic tools?
thanks, regards
I'll add a picture to show what i mean:
So basically i wonder where i find the Carrier Frequenzy of a IR Code inside the Lintronic learned Code.
To determine the carrier frequency if you don't know it you either:-
  1. Measure it with a capture (Not Lintronic) program which provides this data
  2. Look it up based on the known protocol. For example RC5 protocol is always 36 Khz, NEC protocol is always 38 Khz and Sony protocol is always 40 Khz
  3. If you have the data in Pronto captured format you can calculate it by taking the second HEX word in the command string (example 67) change to decimal (example 103) and you get (Example --  Frequency = 1000000 / (103* 0.241246) = 40,244 ) or 40 Khz
  4. Measure it with an oscilloscope or data logger
Common Cariier Frequencies are:-
  • Philips RC5 is 36 Khz
  • Philips RC6 is 36 Khz
  • Philips RC-MM is 36Khz -- Used for multi media products
  • Philips RECS is 38 Khz
  • RCA protocol is 56 Khz
  • Sony 12, 15 and 20 bit protocols use 40 Khz
  • Sharp protocol uses 38 Khz
  • Nokia protocol uses 38 Khz
  • JVC uses 38 Khz
As you can see most companies use 38 Khz, so if you do not have capture facilities which can provide the carrier frequency, then try 38 Khz first because more often than not it will be 38 KHz you are using.
🙂 thanks Keith, that is very helpful.
