Light dimmer
I have bought a LK FUGA® indsats lysdæmper TOUCH IR 350 UNI
Hello.
I Have the same problem...
Pleace sombody help...??
/Uldall
As far as I know LK Fuga dimmers are controlled by colored buttons in LIGHT mode.
Try command: 0:000:LIGHT:CNTL_STEP_UP for Light - blue.
Hi Uldall
I can see your are from denmark
Read this PDF-file
Remember to check the Continuous checkbox, this will repeat the latest command in the IR list.
Hi Tillquist
Mange tak så virker det :)
/Uldall
I just read your post dating from 2009 concerning the LK FUGA Dimmer.
Did you manag to install it in a standard-european-socket ? Or is Sweden based on danish electrical standards ?
Best regards,
Jean-Luc PUTZ
