moxxey wrote:
No-one said that, as a rule, the new iTunes Plus audio tracks are now 'better' or more 'superior' to those from CD (ie. a lossless digital computer version). However, they are definitely far superior to the old DRM-based tracks that you used to get from iTunes and were ripped from CD. The new tracks are now sourced from the original audio master, from the publisher and are therefore far superior to the old tracks.
Ok, let's break this down:
- old tracks from iTunes were DRM-protected 128 Kbps and of very limited quality; thus, mainly targeted for your average sound system (one would hope non-B&O) or portable device.
- the new iTunes Plus tracks were introduced in May 2007, they were now DRM-free and at 256 Kbps, 30c extra per track and available for selective (EMI) albums; let's agree these were now "far superior" to earlier tracks (i.e twice the resolution of pre-existing tracks and twice or more the quality due to direct sourcing from the audiomaster).
- as of April 2009, all songs are now available in the iTunes Plus format ranging from 0.69c to $1.29 and are pretty good value.
Got it! And I hope that was not the basis for B&O to "restrict" the old BeoMedia1 (BM5's predecessor) to 196 Kbps playback but that's a separate argument for another forum at another time...
moxxey wrote:
As these tracks are created from the original sound source, the quality is far far better than old tracks. Indeed, they are better than those on CD - I've bought various recent albums (Depeche Mode 'Sounds of the Universe' is a good example) and the same version from iTunes. Both myself and a music publishing friend thought the iTunes non-DRM tracks were superior to those on CD. The iTunes tracks were more dynamic.
This is the bit I was trying to tackle in my previous post BTW. I have this same album, I bought it last month. I have compared it (and many others) against my prior album versions downloaded via iTunes Plus. I have also compared them against AAC lossless (i.e. MPEG-4 Audio Lossless Coding supported by MACs and not officially supported by BM5 but installed the codec nonetheless) and WMA Lossles (i.e. Windows Media lossless - currently supported by BM5). Outcome:
1. WMA Lossless - best output sound.
2. AAC Lossless - second best but inferior to 1.
3. AAC 256 Kbps (from iTunes Plus) - good value, easy to source but inferior to 2.
4. AAC 128 Kbps, MP3 128 Kbps et al - poor quality, in conflict with B&O equipment or an audiophile-like setup.
As for older recordings, I am not sure you can put a time bracket around it but if you feel lower resolution tracks sourced directly from the original audio master are superior to tracks ripped of the original CD, fine, I'd go with that (but not necessarily under the premise there's not enough disk space - that constraint is so easy and cheap to remove nowadays). BTW, I did not get my friends to listen to the comparision tests above for the simple reason I don't trust them 🙂 Many things get in the way unless the tests are blind.
