IR Receiver?
Hi
I connected my BV4-50 with a Onkyo NR-TX1008. The Onkyo is hidden in a cabinet. Unfortunately I canot control the Onkyo through the cabinet with my Beo6 IR, so I have now a Logitech Harmony 900. To be honest the Beo6 looks much better and I would like to use it. So my question: is there something like a IR receiver? I would like to set up the IR receiver next to the cabinet and put the other end into the cabinet. So that I can control my Onkyo without opening the cabinet.
Thank you in advance
If your third party STB is hidden in a cabinet, then your best option would be a Lintronics box.
I have used these in the past. Just sold a pair on ebay last month.
link
Or maybe the newer version
Exeter,
Devon,
UK
Since you are operating within a cabinet, you probably also have room to use a wired IR repeater.
Niles has a ton of IR integration products.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
