Ir Range really poor!!!!!!!!!!
just wondering if anybody else is experiencing really poor range on their 3rd party products especially my virgin media box.
I have made all the usual checks ( not in dealer mode) and have even replaced the display on it today but the range is still only about 2ft at its best mainly on the virgin media.
The most likely reason is the Carrier Frequency is incorrect
Thankyou Keith i'll have a little look around on google and see if i can find how to changed this, thanks once again.
Hi Keith sorry to bother you is there any software available that will convert these to files to xml? also what are these files i have, are they hex?
sony lcd
717012001009000000000003=0
717012001000000000000003=1
717012001001000000000003=2
717012001002000000000003=3
717012001003000000000003=4
717012001004000000000003=5
717012001005000000000003=6
717012001006000000000003=7
717012001007000000000003=8
717012001008000000000003=9
717012001056000000000003=ANALOG
717012001037000000000003=AV
717012003079000000000003=BLUE
717012001017000000000003=CHANNEL DOWN
717012001016000000000003=CHANNEL UP
717015059210000000000003=DIGITAL
717012001117000000000003=DOWN
717015082061000000000003=FORMAT
717012001092000000000003=FREEZE
717012001101000000000003=GO
717012003077000000000003=GREEN
717012001058000000000003=INFO
717012001052000000000003=LEFT
717012001096000000000003=MENU
717012001020000000000003=MUTE
717012001021000000000003=POWER
717012001047240000000003=POWEROFF
717012001046239000000003=POWERON
717012003076000000000003=RED
717015075163000000000003=RETURN
717012001051000000000003=RIGHT
717012001023000000000003=SPEAKER
717012001059000000000003=SWAP
717012001063000000000003=TEXT
717015075182000000000003=TOOLS
717012001116000000000003=UP
717012001064239000000003=VIDEO 1
717012001065240000000003=VIDEO 2
717012001066241000000003=VIDEO 3
717012001073239000000003=VIDEO 4
717012001072238000000003=VIDEO 5
717012001073239000000003=VIDEO 6
717012001019000000000003=VOLUME DOWN
717012001018000000000003=VOLUME UP
717012003078000000000003=YELLOW
Onkyo Reciever
716210109159096000000003=AUX1
716210109009246000000003=CD
716210109002253000000003=CHANNEL DOWN
716210109002253000000003=CHANNEL UP
716210109131124000000003=DOWN
716210108140115000000003=DVD
716210109013242000000003=GAME
716210172212043000000003=HDMI1
716210172213042000000003=HDMI2
716210109132123000000003=LEFT
716210002194061000000003=LEFT_NET
716210108082173000000003=L_ALLSTEREO
716210109068187000000003=L_DIRECT
716210108076179000000003=L_STEREO
716210108077178000000003=L_SURR
716210109005250000000003=MUTE
716210109151104000000003=OK
716210108071184000000003=POWER OFF
716210109004251000000003=POWER ON
716210108084171000000003=RETURN
716210109133122000000003=RIGHT
716210109014241000000003=SAT
716210108083172000000003=SETUP
716210109008247000000003=TAPE
716210109011244000000003=TUNER
716210109130125000000003=UP
716210109015240000000003=VCR
716210109003252000000003=VOLUME DOWN
716210109002253000000003=VOLUME UP
Gary,
What you have found has come from the Lintronic web site and are Lintronic code sets.
The first 3 digits define the code set in question with 717 being for Sony and 716 being defined as an NEC protocol. The following digits are the associated parameters and are used by the Lintronic boxes firmware.
If you have purchased a Lintronic converter box, then you would use these codes and you can also capture your original remote codes and convert them into an XML file.
Theres just 3 hurdles left in my way to overcome,
  • convert this hex
  • convert this hex  link    file to xml.
  • Change carrier frequency on virgin +, is there any software out there that does this?
  • Third and final problem which i can live without, when i add "video 1" to a macro i'm prompted with "string is too long" message and does not add this key to the macro, and when i try to rename the key it deletes the ir coding from it and replaces it wit "50ms" so just a gap.
Is there not a way to use my logitech remote to learn ir codes? the only problem is that it keeps all its files on a server i believe.
Thankyou for all your help Keith if there is anyway i can help you out at all then let me know and i'll see what i can do.
Here you will find the an XML file with the converted codes.
http://www.rungwald.dk/SonyLCD.rar
You should not change the Carrier Freq on the box, it should be done in your XML file, so you need to find out what freq the box uses.
/Weebyx
Thank you ever so much Weebyx For the sony lcd codes but they did not work, the sony trinitron xml works but its so old it doesnt have any hdmi selection:(
is there any way i can edit my xml file and change the carrier freq for the virgin media stb
or is it much more difficult in practice.
Many Thanks
G
Gary,
The Virgin Media + I previously provided you with uses RC5 protocol and a carrier of 36 KHz which is standard for RC5
The Carrier Frequency can be changed in the XML file, but first you need to determine what frequency it actually is. If you know what protocol it is using then we can make a good assessment. For example if it is NEC protocol then the carrier frequency is always 38 Khz. If it is a Sony product then most are 40 Khz.
Sony Trinitron uses standard Sony 40 bit protocol with a Carrier Frequency of 40 Khz
