IR code setup
It's been a few weeks since I saw my dealer setting up my IR codes and now I'm in a position to configure my own 😕 I'm struggling to remember how it was done.
Could I have a reminder please?  Perhaps the best way is to pick a real life example - for example how would I set up the codes to go to the recorded programmes section on Sky +?  On a Beo 4 this would be Go, 1, Green...
Help! Anyone?
You have a PM
Hi BEO5 users
I have been to the dealer 4 times now to get it configured right.
I also have the lintronic box at home, controlling other hardware than my B&O.
BUT STILL not working correctly at controlling all the hardware.
Anyone with the config software install package, i would really apreciate.😕
Regards
Jacob Just
\Denmark
Hi Jacob, check out my post on Beo5 with Sky + - it tells you how to set up the code for accessing the planner.  (Go-1 then Green)
If there is anything else you want to do, post it and I will try to help.
Thanks,
Martin.
