The macbook accepts ir commands. . .is there a software to capture them?
I need a couple commands. . .my fan, fireplace and another tv
thanks
MJM
thanks
MJM
Sometimes i dont understand people.They spend a lot of money for a Beo 5 remote and B&O product and for a converter they want to spent nothing.To let read out a remote is coasting around 90 pound.If you have 3 remotes to read out its costing already a Lintronic box.Lintronic works easy And if you buy in the future other product its easy to make a file again.I did already read out in this house 12 remotes.
Regards and a happy new year
Kammeri, that looks interesting, will look into IRScope a bit more
<Quote>Could this help link? Basically it should give the same output for programming reasons as the Lintronic box does, although I am not aware of the post processing procedure of the signal. Someone please correct me if I'm wrong.
So how do I convert to an *.xml with this tool?
the link announcement by Keith on Feb 8th 2009, you just need RC5 codes for your "Remote Control" and off you go to your dealer with the XML file
