IR Capture
Hi all
Can anyone tell me what I need to capture the signals from my third party remotes, in order to create an XML file to upload to the Beo5? On the help pages Keith states:
"...if you wish to produce your own templates for a product not currently available from B&O or this site then you will need a means of capturing and decoding this IR signal. There are many cheap solutions available on the web, but if you happen to own a Lintronic converter box, then you can use that."
I don't have a Lintronic box, so what do I need to buy? What is it called? Google is not proving helpful in this instance! I have a Macintosh computer, if that is relevant.
Thanks in anticipation
Stuart
Hi Stuart
You need the
I'm in the same boat Futurist. I'm a mac user who'd like to capture codes without having to invest in a Lintronic box.
I've heard that a Sony PSP will do it, although I haven't looked into what software would be needed both on the PSP and my Mac
Quim43 wrote:
Hi Stuart
You need the link
You also wil need a RS-232 cable and a Power Adapter (both can be bought in the same web) This is the hardware. You will need the software Configurator, that can be downloaded from the Lintronic page as well.
I don't know if it works with Mac, but a mail to Lintronic will solve all your doubts (michael@lintronic.dk)
Regards
Hi Quim
I was hoping for a non-Lintronic (read: cheaper!) solution. It seems extravagant to buy the Lintronic when Keith mentions that there are inexpensive options on the web - I just don't know what they are called.
Thanks anyway.
Stuart
Hi Stuart,
I chose the Lintronic route to program my Beo5 because the accompanying Configurator software allows you to create your own XML file as well as correctly capture the codes from your 3rd party remote.
Even though it is a bit pricey it's a pretty neat piece of kit with a wide range of applications. And whilst I have the Beo5 controlling my TV and stereo - i.e. no need to use the Lintronic box to convert IR signals - I'm planning on using it for some simple X10 home automation.....all controlled from the Beo5 of course!
Cheers,
Matthew
Quim43 wrote:
You need the link
And you also need the USB to 9-pin RS232 convertor, right?
So if I understand it correctly, you only need the Lintronic parts to create XML files to upload to your beo5, to control any product directly. When that part is done, the Lintronic convertor is not needed anymore, until there is new device added or replaced.
Hi
In the beginning, I used a PDA with an IR transmitter and the SW
Could this help
I have also used an iPaq 2210 with RemoteControl II, it captures the codes as philips pronto codes, but converting them to beo5 codes isn't difficult.
/Weebyx
Same here, also used RemoteControl II. It's not as straightforward as a Lintronic solution, but managable for a low number of devices and home use.
Cheers,
Frank
