How to create XML files from pronto codes nowadays?
Hi to all!!
As far I know, the last version of Lintronic Configurator is not compatible with Keith's XML generator 1.1. So what shall we do now? Are there some way to generate XML files from pronto codes?
I will strong appreciate some help. Thanks!
An XML file can be generated from Pronto Hex codes without problems, but not with the XML generator.
If you upload
If anybody got a version of the "old" Lintronic Configurator v.1, we could use the Code Learn section without a Lintronic box, to convert the pronto codes to something usefull.
Anyone ?!?
/Frank
Anyone ?!?
/Frank
An older version of the Lintronic Software can be found
Great! Thank you.
/Frank
