Help with XML generator please
I found this code for one of my products.
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
It's supposed to be an "ON" button. .
Can someone help?
I have the XML generator program and the configuration tool. .
MJM
I followed the instructions
I have just downloaded the last version of the Lintronic software (v2.0.5.3) but the user interface is quiet different from the screen captures shown in this tutorial.
I tried to paste some Pronto codes in the converter but the "Convert" button is still inactive... maybe because there is no Lintronic hardware connected to my PC... is this a kind of protection from Lintronic ?
Regards,
BOMF
Try to create an XML file with the following code, and put in your "Beo5 Configuration Tool\ThirdParties" directory. Then add the product using the config tool.
<?xml version='1.0' encoding='utf-8'?>
 <root stVersion='1.0'>
  <resource><image stName='NonBO' stFile='images\NonBO.BMP'/></resource>
   <product stName='SomeThing' stCaption='SomeThing' stMenuCaption='SomeThing' stImage='NonBO' stProductType='accessories3Party' stScreenType='1'>
    <source_item stName='Some' stCaption='Some' stScreenType='0' stMenuCaption='Some' stSourceType='accessories3Party' nPreferedRow='4' nPriority='1' nPreferedColumn='1' nPage='1' nX='0' nY='95' nWidth='213' nHeight='25' nRowFinal='4' nColumnFinal='0'>
     <source_subItem stName='Some\POWERON' stCaption='POWERON' stMenuCaption='POWERON' stScreenType='0' stIR='RAW:GlobalManual=1#ListOfFlanks=$22D6,$1178,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$A9EA,$22D6,$08BC,$0222,$17B08#IRSEQUENCE=RAW#Carrier=38028#Pause1=65000#Pause2=65000#Comment=RAW FlankList: 50 flanks' stLeave='Rel 1' stIRVideoOp1='F0:TV:' stIRVideoOp2='F0:TV:' stIRVideoOp4='L_F0:TV:' stIRVideoOp5='F0:TV:' stIRVideoOp6='F0:TV:' stIRAudioOp1='F0:RADIO:' stIRAudioOp2='F0:TV:' stIRAudioOp4='L_F0:TV:' stIRAudioOp5='F0:RADIO:' stIRAudioOp6='F0:TV:' stIRVideoOp5Link='L_F0:TV:' stIRVideoOp6Link='L_F0:TV:' stIRAudioOp5Link='L_F0:RADIO:' stIRAudioOp6Link='L_F0:TV:' stIRVideoOp2Av='F0:RADIO:' stIRVideoOp4Av='L_F0:RADIO:' stIRVideoOp6Av='F0:RADIO:' stIRVideoOp6AvLink='L_F0:RADIO:' nPage='1' nX='0' nY='20' nWidth='213' nHeight='25' nRowFinal='1' nColumnFinal='0'/>
  </source_item>
   </product>
 </root>
This should be the on button for your product.
/Weebyx
I got the same result in the XML generator.
Do i just copy and paste the result in to the BEO5 config folders?
Also, I assume I need to do this for every button I want?
Thanks again for the help
MJM
