Hi Guys
A little Chistmasgift. You can download the BEO5 Config tool v3.23 here: http://www.megaupload.com/?d=90Y55ZZW
Merry Christmas
/Frank
Hi Guys
Merry Christmas
/Frank
Thanks a lot Frank.
I wish you a Merry Christmas and Happy New Year ! 🙂
BOMF
Hi.
What login and password should I use?
Regards
Magnus
You don't! Just use it offline - the log in is for a dealer log in and password. Not necessary for programming.
Does someone have a changelog of this new version? We lack of changelog for every B&O product, in order to know what software version helps for one's precise problems...
There is a changelog in the built into the opening screen of the tool on the right hand side.
Cheers,
Frank
Not when you are using it in "Off Line" mode
There is a changelog in the built into the opening screen of the tool on the right hand side.Not when you are using it in "Off Line" mode
You mean there is more than this in online mode? Login to view image
Cheers,
Frank
Yes, that is exactly what I am saying.
What you are seeing here are the updates that were made prior to the Installation file being produced. When dealers login they receive updates which are appended to the list. If you are not a dealer and use it off line, then that update notice will never change.
