Does the Config Tool 4.11 work with Win 7 (64) or Mac?
appreciate a feedback
Win 7 (32) - YES
The application is able to run on a Win 7(64) PC ,
but it's the driver for Beo5/6, that will not work with 64 bit versions of Windows
>>  No driver >> no contact to the remote control!
Win 7 (64) - NO
You can get the config tool  working on a win 7 64 bit machine by installing and running win XP virtual machine within Win7 which is a free download. Then installing and running the config tool within the XP VM environment
Saves having a seperate laptop for the CT software!
Cheers
Steve
Thanks, yes I have Win XP installed under Paralles but it is always some hassle with the USB devices with the virtual machines but I will have to go that path then.
