Do you own both a Pioneer KRP500 & a lintroinc box?
Hi guys
Having some trouble programming my beo5 for my pioneer KRP500. Apparently this product is a bit more tricky than others I have.
If someone has both of these products I would really appreciate if you could learn some codes from the remote with the lintronic box and send me the result.
Keith has been extraordinarily helpful but we have yet to find a solution and my BEO5 is just sitting here not being used.
Hope someone out there can provide some codes.
If you have a Pocket PC or a Windows Mobile based smartphone with Infrared you might want to give the software RemoteControl II a try. I was using it to get the codes for my Pioneer DVD player. The reading of commands also works in demo mode.
Cheers,
Frank
Anybody?
I too have a Pioneer KRP and would like to have on/off working with Beo5. Remote type is Pioneer Flat Panel Display AXD1570. Any help would be much appreciated.
