Direct control a Samsung BD-C7500
Does anybody know whether it is possible to direct control a Samsung BD-C7500 Blu-Ray player using the Beo5 remote?
Is there any sample XML's available, or can I just use the Samsung BDP4600 in the Beo5 XML for direct control.
I do not want to use the PUC from the TV unless absolutely inavoidable.
Any help would be much appreciated.
I have made you an XML file for the Samsung BD-C7500 player for DIRECT control, but it is not tested, you will need to do that.
You can download it from
