I was about to suggest battery disconnection, though I have never dome it.
Maybee you could let it go completely flat to force a reset?🤔
Dead Beo5?
Already started doing this but it is going to take ages!!!!! I have to press now and then some button otherwise it goes on sleep so we will be having news next year!!!!!
The best solution if there is something like a master reset would be to remove the battery but as mentioned before this is NOT my task.
And I'm also waiting for my BV4 and was going to start the new set up 🙁
Still Beo5 has not drained from the battery!!!!!!!!!!! And of course still no response from the Beo5
Hi Spiros
I would wait till Keith Saunders comes back from vacations. He will help you for sure, if your Beo5 is not dead as you ask in the post title.
Regards
Quim
Hi Quim,
Indeed this is what I intend to do. Wait for Keith's advice before do anything actually!!!
But it's a long vacation!!!!!!!!!!!!!!!!!!!!!!
Best regards
Spiros
