Connection to Radiostation lost
Hello Beo Forum Community
I have a strange problem with my BS5 / BM5. A few days ago I liked to listen to DRS3 (Swiss radio station). I selected the station and after 1 or 2 seconds the connection was lost. Since then I can not listen to any DRS radio station (i.e. DRS1, DRS2, DRS3). Other Swiss radio stations (and radio stations from other countries) are working fine.
I can listen to DRS3 by wire, by N.MUSIC via PC, in my car. I visited my B&O Dealer and DRS3 is being broadcasted by BS5 / BM5 without any problem. It looks like BS5 / BM5 lost only the connection to the DRS radio stations.
When I select the radion sation DRS3 on ths BS5 (regardless via "Countries" or "Favorites") the name of the radio station (far left) does not blink, it stays darkgrey.
I tried to find any informations in the service menu (i.e. a "Radiostation folder" or a "Radiostation list"), but could'nt.
Does anybody have a idea how this problem could be solved? Even my B&O Dealer is helpless (and the guys are good) at the moment!
Regards and thank you for any answer.
Wulf
System Informations:
BM 5
Application: 4.02.01.1291
Firmaware:   2.27
ML PCB:      4
MB BIOS:     1.05
BS 5
Main Firmware: 1.30a
Boot Firmware: 0.04a
PCB:           3
BOM:           3
Listening occasionally to the same stations as you do through BS5-BM5... most recently last Thursday. Potentially reinstall Beoplayer and confirm registration and reload radiostations ? Otherwise, you may do a reset on BS 5 and see if the stations are properly reinitiated.
Greutzi !
No problem listening to DRS3 here on N.RADIO for 6 hours now. The music strength is clear, with no signal dropouts either.
Agree with a reset of your BS 5: Hopefully that will solve the problem for you.
Thanks for the answers until today.
Below you'll see what my B&O Dealer found in the B&O Problem Data Base 😕
Registered Quality Problems:
When starting N.RADIO after standby or by Play timer the station stays grey and cannot connect, no sound (85322)
Symptom:
When starting N.RADIO after standby, it cannot connect. The N.RADIO station name is greyed out and no sound is played.
Deadline:
High priority case.
Work-around:
Step up or down on the remote control - after getting a connection to the next or previous N.RADIO station, you can step back to the station you wish to play.
The "Work-around" sounds good, but does not work with my BS 5 🙁, so I have to wait until the problem is solved.
Regards
Wulf
