Confused about zones
I want to create a setup with a BeoSound5 and a BeoSound 3200 in the same room. When I try and do this in the configurator it wants to create two zones. Why is this? I am confused.
Maybe it`s because the config tool "thinks" your BS5 is audiomaster and BS3200 is audiomaster too. So two audiomasters won`t work and the config.tool creates a new zone. Try to install video- and audiomaster first, then video- and audiosources. You will find "Beosound 5" in "Audio". Don`t choose "Beosound 5 audiomaster". Hope this helps.
Stefan
- Create one zone
- Add the BS3200 and speakers to this zone
- Double-click the BeoSound 5 AudioMaster from the Product Browser
- Click on OK for an extra zone
- Click on the Edit tab
- Hide the extra 'Zone-1' from Zones
That's it !
If you have assigned your BS5 as "NO AUDIOMASTER"in the BS5 menu, and I assume you did, because your BS3200 must be your audiomaster, then just add BS5 as no audiomaster in Beo5 CT as well. You won`t need any workarounds with extra zones and hidden buttons....
Stefan
I keep getting a message about the need to add a video source before the BS5 (no audiomaster) can be added.
