Channel Logos
All,
I have a problem when I am trying to put in channel logos on the Beo5. When I build the layout everything is fine but when I want to download the new layout into the Beo5, it starts but after 30-60 sec it says write timeout and stops. After this the Beo5 works fine but it has not received any changes from the new layout ?
Also, I have downloaded some logos from
Did you remember that logo must be max 92x44px?
I have made around 50 logos for myBeo5
No, how do I do this ? I was not aware, as they work perfectly fine in the Beo5 software program when designing the channel lists ?
You down scaler image in your Photoshop program and remember that it must be on a black background
You can use
Hi, I have experienced the same, but the solution to me was very simple. Release Beo5 from the docking and put it back again.
