Bs5 to B9
Gents,
I've got the bm5/bs5 connected to a bv9 as the dtv.
I can get the bm5 screen but cannot control it.
I've tried it with a 3.5mm cable connected to the control of bv9 and ir of bm5 and with no 3.5 mm cable.
Any thoughts?
Hello mjmedio,
I think that bm/bs is cabled with ML to the BV9 ??
Try to connect the bs/bm as "pc" .....
it should work ;-)
Niederrheiner
I have it connected to my ML network.
I cannot get any control over it? Does it respond to PC commands over the network ?
To further the dialogue.
My bv9 shows the PC as av5 but it is grayed out.
Normally you can control it by N.Radio/N.Music over ML
And it accept PC commands over ML-Networks
Why is PC grey?? Used by another ??
Niederrheiner
Did you connect it's video via  hdmi ? This will not work ...
you should connect the BM5 via the VGA input and not via the hdmi.
The BS3 detects it is a BV9, so it assumes a BM1 is build in in the system, connected via VGA...
if the ML cable is connected it should work when you select PC
you do not need a IR input on the BM5
regards
nico
Sounds like your BV9 has a built in beomedia 1. This needs to be removed or disabled before you can control the BS5
