BS5 sw update version 6.03
A thought, maybe try shutting the Twonky app down, turning the Beosound on, and then turning app on. I think I did that once and it helped one of the apps I have tried find it.
Thank you for your advice. I have been struggling for the past few hours to get twonky back on track again, it froze, then the iphone froze, and I had to reinstall twonky, but alas the result is the same. It plays, but it seems from my diskstation, even though beomaster is the player. And when I want to play a track it says unable to start playback because beosound stops on PAUSE - I wonder why.
Anyway here is my library : diskstation (selected), eyeconnect, twomky server (8iphone), I press music, press iphone icon down left >select beomaster5 as player, so the tracks come from my diskstation, don't they?
Greetings
carsten
In imediacontrol beosound does not go on pause, but it still get the tracks from my diskstation......
Greetings
carsten
I am not sure what a diskstation is. I get the same message about unable to start playback. Pressing play on the Beo 4 will start it.
The diskstation is my synology nas harddisk where I keep my music backup - apparently twonky and imediacontrol for that matter can only see the diskstation, not beomaster5. I take it that your library says beomaster5??
Greetings
Carsten
Twonky locates and displays Beomaster5. Have you tried the eLyric app? It seems to work the best for me.
All is well now. Somehow music server was again off even though I had put it on, so now device is beomaster5. Thanks a lot for your time. The only  problem was myself 😁!! Using imediacontrol (does not pause)
Greetings
Carsten
