BS5 and speakers connected to BV7
Dear all,
Is it possible to connect the BS5 to a BV7, speakers connected to BV7, and still have audio from the speakers without having to push PC on the Beo4? I used to have a BS3200 connected to the system as well and then there was no problem at all. Now there is is no audio unless I activate the PC function of the BV7. BS5 is registered as audio master and BV7 as videomaster with speakers connected (can't remember which option).
Problem will be solved once I get the chance to connect the entire system again but for now it would be great if I could get audio from the speakers without pressing PC since that means I will get a picture on the screen as well.
If your BS5 is set to audiomaster and A.OPT 0, the BV7 to V.OPT 2 it should work pressing N.MUSIC or N.RADIO. Should even work with a BS3200 connected if your BS5 is set to NO AUDIOMASTER - works in my setup with BS9000.
Hope this helps.
Stefan
...and it works like a charm. Many thanks for your assistance.
/Emil
You `re welcome - enjoy.
Stefan
You should also be able to set the BeoSound 5 to react to CD and RADIO, in this way you don't need to press LIST first.
/MikaelB
/MikaelB
If I remember correctly, You have to set the BeoSound to Audiomaster before you can configure CD and Radio to replace N.Music and N.Radio.
