BS5 - Always on standby ?
Hi everybody,
I got my Beosound 5 system now over one year. Great, no problems but one. When I shut down the system via my remote or at the controller, on both speakers the RED standby light keep burning. It becomes green, once activated again
As I am often away for a few days, I find it strange that the system ( as far as I know ) cannot be taken completely from the mains ( except pulling the plug out - but this I do not even do with my computer ! )
Am I of something not aware off or is it a fact that the units always remain in standby?
Your comments are appreciated
The speakers always remain in standby while plugged in, and so does the BS5/BM5 unless the Beomaster 5 has a mechanical mains switch somewhere (I'm not sure, probably not). Most B&O kit has been designed that way.
BTW with the same caveats, your computer stays in standby as well!
Thanks for your response. No, there is no mains at the Beomaster 5. Again, thank you
No problem 🙂
If you were thinking about the standby power consumption, the Beomaster 5 actually consumes very little, 1-1.5 watts. Older non-ICE speakers will use a little more - a Beolab 8000 takes 1.8W for example - but the combined standby consumption of a BM/BS5 and two speakers should still stay under five watts. An ADSL router will probably use more!
Yes - I was wondering about the consumption. But it is really not much, nothing to worry about. Again, thank you very much ...
