Blue Screen on BS5/BM??
Hej gronkjaer,
det var jo et ærgeligt svar at få fra sin forhandler. For hvad er lang tid - er det flere uger? Da min forhandler fortalte mig at der kom en tekniker ned til mig, der gik der en 3 uger, men det var også fordi, at der var dele i restordre.
Vi kan jo hurtigt blive enige om, at det bare ikke er godt nok, men det er da utroligt, at de ikke har reservedele på lager, men det er vel fordi, at der er så mange der har problemer med BM5! Man skulle vist have vist folkene i produktionen hvordan man sætter RAM i en sokkel.
Håber du får den hurtigt tilbage så du kan nyde din musik igen.
/mite
Tjah, nu er skidtet sendt ind! Så må vi se hvordan det går ? reservedelene er i restordre, så jeg er også stillet i udsigt at det nok tager en 3 uger, oveni er julen jo lige om hjørnet, så der kommer jo nok reelt til at gå noget længere tid :-(
Men det er et fedt musik anlæg når det virker! Bare ærgeligt/ringe at det ikke afspiller FLAC ? Har du succes med det Mite ?
...can I ask my fellow beoworlder to either continue their discussion in the Scandinavian forum or keep it in English on the BS5 forum. Thanks...and don't take it as a vote of non confidence into your lovely language.
Sorry mate, of course, you're right. If we continue?, we'll continue in english !
... thanks. As I have BS5 as well, thought I might miss something.
hope you can resolve your issues.
rgds PF85 / Peter
Well peter, we was just discussing that BM5 had issues with the motherboard and the ram modules. the issues was that with the old motherboard you had to press down the RAM modules in the middle of the RAM module and not as normal, just a clip in each side. This pressure right down in the middle of the RAM module could cause a crack or tear in the print circuit which could in the end lead to a malfunction. This was a common issue on the first BM5 they(B&O) send out to their customers. And unfortunately i bought one of those machines. So now its getting repaired in Skive, one of B&O repair service centrals, but they don't have the parts available, they are out of stock. So i have to wait, and now i'm getting nervous that i don't get it before Christmas!
thanks Gronkjaer for clarifying.
I had to replace the M/B as well on my BS5... in my case the dealer got a so called repair kit... took about 2 weeks and then was able to repair overnight. Hope you get yours back before Christmas.
